bigceltic
Stock 5. 9L (other than gauges, Mag Hytec trans pan, and PSM air intake - see sig). Got a brand new Smarty Jr on Friday and installed Program 2 (Towing) with default settings. Followed directions and everything seemed fine. Sat morning I started it and got the WIF light and DTC (P2269). I was at half tank, having filled up earlier in the week and driven too and from work (to include picking up my trailer) with no probs. I shut engine off and used the Smarty Jr to revert back to Stock programming but WIF light stayed on. I changed the primary and secondary fuel filters (I have the Mopar Severe Duty Fuel Filter kit with 2nd WIF sensor) and checked the fuel I drained for water and there did not seem to be any whatsoever - light stayed on. I tried clearing the code with the Smarty Jr but light stayed on. I am freaking out as I am leaving today (in a couple of hours) for a camping trip and pulling my travel trailer. I suspect it is a sensor issue, or that there is something to do with the extra (2nd) WIF sensor on the Severe Duty Filter (I saw something about ECU voltage or something in another forum).
I reinstalled program 2 (towing) with default settings and took the truck for a drive. Seems to work perfectly. I got back and disconnected both batteries for 30 mins and reconnected. WIF stays on.
Any insight? I do not have the the tools or skill to test the sensors themselves. Could it be battery related (orig batteries on truck, 84K miles on truck)? Is there an easy way to check the sensors if you are not very electrically astute?
Help!
Help!
