I am in need of advice. Pulling a 9K TT, my transmission started jumping in and out of TC Lock. I was running on level road about 60 to 65 MPH. Needless to say the fluid heated up. I flipped my TC "magic" switch, and the TC stayed locked up, fluid cooled down, with no further problems.
Later got into some hilly country, coming out of a town, and TC would NOT lock up... (shifting from 2nd to 3rd). . without the manual switch engaged.
After dropping the trailer, the transmission works like a champ. Not a hint of a problem without pulling a load.
Question to anyone, first off, any idea what the problem and/or fix might be? Second, and more importantly, can I pull my trailer back home, using the TC Manual switch, with success, and without further damage to the transmission?
Thanks for you help!
99' Quad Cab, ETC, Auto, 4. 10 LS, Di Pricol EGT, Boost, & Trans Temp. Gauges (from TST), 275 Injectors, Practical Solutions Boost Module/Elbow, Torque Converter Lockup Switch, with complete AMSOIL fluids.
NRA Member
Semper Fi
NRA Member
Semper Fi
