Help exhaust brake?
Problems with Geno's fuel pressure gauge.
Pshcotty and 4 1/2 hole saw help
Today i installed a bd inline brake removed the turbo setup brake and after the install i started the truck and it seems to have like a high pitch whistle could it be because of the ehaust and having the brake furthe in instead of at the turbo or could this be what the inline one sounds like thanks for your help
99 24v auto 3500 4x4 reg cab 3. 55 axle,ez edge,275 injectors,k&n,rhino lining, tinted glass, tonnoue cover heavy duty trailer tow set up goose neck hitch draw tite brake setup,cb,cd player,catz back up lights,amsoil frnt to back,jre exhaust4 wire blue box,bd exhaust brake,transgo shift kit, a pro torqe extreme convertor, and a magtec trans cover and trans guage,JRE fuel line kit,upgraded fuel pump,braided fuel lines from lift to injector pump,reflashed ecm,fuel pressure guage,3 guage pillar,boost&pyro
Sounds like a simple exhaust leak to me... Make sure all clamps and manifold bolts are tight. Also, I have seen exhaust brakes have small leaks on the pivot points of the butterfly valve. These leaks usually "cure" themselves as carbon builds up. One last thing, make sure the backpressure is adjusted right. About 21-23 lbs is ideal for most applications. Should spike up to 50-55 under heavy braking.
massdiesel:
ho does rhe brake work? i'm thinking of getting one and want some insight on how well it works compared to not having one at all. i hear having one will pay for itself in brake jobs in the long run. hope you get that wwhistle worked out! also, we new england TDR members are trying to get a local tri state chapter going. check out the strand in the local chapters forum if your interisted.
Hi Massdiesel, Just wondering what kind of transmission mods you needed to get somethying out of your brake????
brake
if the whistle is coming from the exhaust when the brake is on, this is normal... if it is whistling while the brake isn't on, check for an exhaust leak.
