Help finding trans pres. actuator?
excessive crank before starting
CP3 or other problems
I'm hooking up a DTT Shift Enhansor and can't find the location for my last hookup. It's supposed to be at the trans pressure actuator, the orange wire, I've been looking for an hour and can't find it. Can anybody help I've already posted on the thread and want to finish this. Thanks. :confused:
Guess I'll have to wait till tomorrow since the only connector I found close has 6 wires instead of the 5 listed. Even this plug is so hard to get off it appears you have to remove the housing to unplug it. Needless to say I'm really frustrated I was hoping to see if this fixed my problem or if I really have trans problems!:mad:
Have you looked at the part immediately above the shifter cable on the driver's side of the trans housing? I forget how many wires are running into it, but it is a small electric motor, mounted with two bolts that sits on top of the shaft running into the housing with the shifter cable.
If this doesn't work, try a Goerend valve body. That fixed the problems I was having with my stock & my built transmissions.
Ben
