You could do it in a day. Once you get it buttoned back up, turn the key on and let the lift pump cycle. If it only cycles for 2 or 3 cycles, "bump" the starter to get it to run for 30 seconds or so. You may have to crack open number 1 and 3 injector crossover tube nut to get the air out so it will start.
