Engine/Transmission (1998.5 - 2002) Help, injection pump ?
Engine/Transmission (1998.5 - 2002) 53 Block Defect Register
My friends truck died yesterday and had it towed to the Dodge dealer. Was told this morning that it was the fuel injection pump and would be $2400 to repair. Does this sound right? How can it be checked? Is it difficult to put one on? Truck is a 98 or 99 with 76k
You could do it in a day. Once you get it buttoned back up, turn the key on and let the lift pump cycle. If it only cycles for 2 or 3 cycles, "bump" the starter to get it to run for 30 seconds or so. You may have to crack open number 1 and 3 injector crossover tube nut to get the air out so it will start.
You could find a local shop with a scan tool and then check the codes against the 24V Code List in the 24valve FAQ section. 0216 is a failed pump, I cannot remember all of them.
