HELP...NO CRUISE CONTROL
Hole saw
HELP, Help me buy my Ram!
My light on my cruise went out and I dont see a fuse for it listed. It quit working going to town and I cannot find anything about it in the owner's manual. What could be wrong??? Please help me before the dealer get's into my pocket... Dang trunk only has 33,000 miles!
1993 Dodge Prostock Daytona 7:70@172, 1987 Grand National 11:77@115, 1996 Dodge Ram 3500 Dually. Stock with a 5 speed, Home page http://www.home.earthlink.net/~whra3
Hyper,
Is your airbag light illuminated? If it is you need a new clock spring.
94 2500 SLT 4x4 5 Speed, 3. 54 LS, JRE 4" exhaust,Autometer Pyro & Boost gauges, Bosch 215HP injectors, Timing @ 14. 7 BTDC, JRE Stage III #4 plate 270/675, AFC spring kit,Pschotty Air, Optima Red Tops, Geno`s Exhaust Blanket, Synthetic lubes throughout.
HEMI,
I hope it ain't the clockspring. Damn near couldn't find one. When I did, I had to make my own left handed torx drive to install it.
On a more serious note.
Hyper, you didn't say if the cruise was still working or not. If it is, it's either the lamp or the PCM lamp driver has failed. If the cruise is not working, things can get a bit more complicated. It could be the switch on the steering wheel isn't closing, the PCM isn't getting the closure signal due to a broken wire, or the PCM has a malfunction.
<font color=#990000>~<font color=#990000> '99 2500 SLT <font color=#990000> ~ QC ~ 4X4 ~ LB ~ Auto ~ 4:10 LSD ~
<font color=#000000>*<font color=#990000> BD E-brake<font color=#000000> *<font color=#990000> BD Autolock<font color=#00000> *<font color=#990000> Gear Vendor OD<font color=#000000> *<font color=#990000> Jordan Research T-brake <font color=#000000> *<font color=#990000> Bullhide spray-in Liner<font color=#000000> *
<font size=-2>... Lookin' for the 'RE' to go next to my 'TIRED' so's I got more time to Play!... <font size=-1>
[This message has been edited by Rattlin (edited 08-12-2000). ]
If the cruise quit working, here is what happened to me... (on a Chev truck).
Brakelight was out on one side... cruise would not engage for anything. Someone at work told me I had a brakelight out, so I changed the bulb. Cruise worked fine. Cruise must sense power in that circuit. May be the same on Dodge.
Rob Hanson
1999 "Big Red", 3500 SLT QC 4X4 6 spd, 4. 10 LSD, Braided SS fuel lines, Mag-Hytec Rear Cover, Cummins E-Brake, Blue Box, Bosch 275HP injectors, All-steel Cowl Induction Hood, Rhino, Rosewood Kit, Scotty System, SportComp Gauges, TorkLift SuperHitch, Teshonka Brake Controller, Rear Flood lights, Cobra CB, DeeZee Running Boards, and a Geno's "I tromped a Ford" decal. Member of BOMB! (WW NW Chapter)
MyPics.com (pics updated 6/30/00)
I'd rather be... .
Cummin than Strokin.
Some circuits use the light bulb as a fuse, if they did this change the bulb and it should work.
99 2500 QC/LB 4X4, ProTorque TC, BD Valve Body,
TST 275hp injectors, PowerMax & VA CPC.
60 Gal. Aerotank, Geno's Combo Gage, Espar Heater,
HX40 Turbo ordered
You are saying I might have a tail light out? Why would dodge use this as a fuse? I will check because I really need my cruise to work. Dodge should have fused the cc like gm did in the 80's. Please keep offering me suggestions as I really need to find this.
Hyper... the chev I owned was an 89 3/4ton 4X4. The stoplight bulb affected the CC. It is worth a try, anyway. Only take a sec to see if your brake lights work!
ok I checked the brake lights and they all work. I rechecked the cruise and it started working again. I wonder what is going on?
hyper on your'e truck and most others the brake light switch also disconnects the cruise control when applied a faulty switch can cause the cruise control not to work. G ood luck.
I know the brake light switch disconects the cruise as does the clucth pedal switch. My problem was that I did not have any power going to the cruise control. I think it was my on off switch on the steering wheel as it started to work again today after a punched the button pretty hard. I guess I need a new one
