Help! ABS light on, no cruise, AC not working
Had 3 recalls done today, in less then 2 hours.....;)
MegaCab manual shift 4wd
KKeen
Hi guys, This is for my brother. He is in the process of signing up for TDR. He has a 2011 3500 dually. He has about 80,000 on the truck and about 4,000 on a new lift with the 22.5 18 wheeler tires and wheels. His ABS light and chime has been on for a week. Shop read his code as the front right sensor (not sure of code number) they repaired a pin in the connector but the light is still on solid. Now his cruise comes on but will not set and his AC compressor will not kick in. Is there any way all these can be related to a needed reflash or something? Thanks for any help. I believe he has a super tuner programmer on it also.
Did you receive any help on this?
I seen that you didn't get any answers on this......... Can you tell me what your brother did to fix this or if he was able to get it fixed. We're having the same problem with our 2012 Dodge 3500. Thanks
