I was leaving work today and lost both steering and brakes at the same time... . I checked the fluid and the nitrogen canister, canister was fine, fluid was full..... I'm at a loss, any ideas
You have what is called a "hydra-boost" on your truck which replaced the vacuum booster a few years back, it uses power steering fluid pressure to assist with brake boost. bgcould the vac booster be bad as well, seems like the PS pump wouldn't cause the brakes to go out too
Kevin
