Help! OIL FIlTER
Need More Power
Can the EZ do what is says it can?
lschultz
It will work till you can get a better one. I use to use them when I had my 91. Dodge had a bulletin out about them.
2000 Dodge 4x4 Quad Cab SWB 5-SP
2001 VW NB TDI
AMSOIL(#504865) DEALER & USER
I need an oil filter and it looks like the only thing I can get on sunday is a fram. The dual bipass mount broke and I need a stock location filter to drive. Will the fram for this application protect they engine or is it garbage.
2001. 5 2500, quad cab, 4X4, ETH/DEE, 4. 10 LSD, 255/85 BFG MT, BD Exhaust Brake, JRE 4" exhaust, EZ w/ elbow, 275's, SPA, Amsoil Dual Bypass Filter, Amsoil under the hood (soon to be everywhere else), Leer topper, Piaa driving 510's in bumper, Line-X, Stereo= JVC KD-MX3000, MBQuart 6. 5 components in front doors, 6. 5 coax in rear, JL Audio Stealth Box sub in center seat, Fosgate 400a4 and 250a2 amps, DynaMat everywhere
I've read that it's garbage. I haven't run a Fram in years.
The Napa Gold series filters are made by Wix. If you could find one of those it would probably be fine.
Or use the Fram for a day until some place else is open.
I guess it depends on how bad you need your truck.
ex Ford tech, now driving '01. 5 2500 4X4 QC LB ETH/DEE SLT 3. 54, Patriot Blue
When my truck was new I took it back to the dealer for a check-up at 1500 miles, when they opened the hood they immediately seen the fram oil filter and pulled it off and said they were junk and if I had engine failure because of it DC would not warranty my engine. Just passing on what the dealer said. I felt lucky since I had just changed my oil right before I took my truck in for there check-up.
Ron
1999, 3500, 6x6, slt, auto, 3. 55, Qd cab, ISB cummins, Isspro transmission temp, EGT, Boost gauges on A-piler, fuel prssure gauge, DD stage 1, DD TTPM, modified banjo bolts, K&N 0880 with prefilter, triple trailing 2001 26RKSS Tahoe 5th wheel, 1999 120hp 1800 bayliner. 20,000 lbs GCW.
Ted - What part broke,the part that the two filters attach to,or the piece that goes on the motor? If it was the one thats on the motor,I make a billet adaptor to replace it that will NOT break or leak.
CPFF
CUMMINS POWERED FAST FORD
The Frame filters are fine for short-term use. The filter paper in them has been proven to break down and actually CLOG engines rather than filter them, but this usually doesn't happen until they've been used for 7000+ miles. If you put the Fram in there and change it out at 3000 miles or so, you should be A-OK.
Greg
Y2K Dodge Cummins QC 2500 SLT Laramie 4x4 Long Bed, 4. 10/Auto, Forest Green/Driftwood, 265x75R16 Michelin LTX, 6 speaker CD, Camper/Tow/Plow Packages, Westin Black Nerfs, Mopar bedliner, Ultra bright diamondplate toolbox, K&N Filtercharger.
http://www.rints.com/hammond for photos!
Not Bombed yet!
