HELP!! Oil Pressure Gauge reads '0'
Omaha area performance diesel shop
Fuel pump question?
While driving today my 'Check Gauges' light came on, and when I looked at the 'Oil Pressure' gauge, it was on '0'
I pulled over and checked the oil level, and it was fine, then called my dealer who said it may be a sensor and to bring it in in the morning. I called another dealer and they said to have it towed in.
The only thing that I did differently just before the gauge failure was to start the truck without waiting for the 'wait to start' light to go off. The truck had been setting a couple of hours while I was working on a house.
Any ideas?
Bob in Sacramento, Y2K Black 3500 ISB 4x4 4:10 LSD,Auto,QC,SLT Laramie, Slightly BOMBED :) LB, Polished Stull Billet Grill & Fog inserts, Chrome Smitty-Built Step Rails, Mopar Chrome-Tipped Mud Flaps, A-Pillar mounted West-Tach Turbo/Pyro/Trans Temp gauges,Rancho 9000's set at '1',Diamond Plated Tool Box, OEM U. R. Bedliner + other stuff.
Fact:The First Fords' had 'DODGE' Engines! The new PSD's need them!
Those electronic gages sre just great! Sounds like you might check into a mechanical gage in stead of getting a new electronic one.
Always ready to help!
2000 2500 Red Sport quad cab, 4x4, K&N, DDI's, straight piped, boost, pyro and fuel pressure gages, Hot Power Edge, EZ box, mean looking set of 33. 5" tires, Snap On diamond tool box, Marine Corps window sticker, Semper Fi!
1972 340 Cuda'. Original tripple Black, 340 car w/air. Good clean car, super stock springs, Weld Prostars, shaker hood, strong 340 with a 727/4000 stahl, 4. 56... . Bombs away!
NRA Life Memberhttp://www.geocities.com/chadsheets
just some info... I had the same thing happen to my 98. . 24 valve the damnn dealer ordered the sending unit and it took 3 weeks to get it. . they ordered the wrong one... there are two wire sending units and also three wire ones... my needed the three wire one another 3 weeks wait with zero lbs. of oil pressure showing for a total of 6 weeks. . gives ya the shakes
the sending unit is below the lift punp on the drivers side of the block check your out and make sure which one they order. .
Gary
My truck did this within two hours of driving it off the lot. I stopped for the night and the next morning it was fine. Four hours later it did it again. I called a Dodge dealer who told me that's a common problem, but DC won't let them stock sending units because they keep installing them. I was also told that I would hear the lifters clattering over the diesel sound if I really lost oil pressure. I never had mine looked at and the gauge fixed itself. I have read that the harness connections can come loose and cause this problem.
ex Ford tech, now driving '01. 5 2500 4X4 QC LB ETH/DEE SLT 3. 54, Patriot Blue
Did a searche in the archives and found several posts with the same problem. Also a TSB:8-22-99. Tomorrow at 6:00am I'll be at my dealer to have them check it out... will keep you posted. Thanks, Bob
My oil pressure gauge is acting up... quite a shock when it goes to zero psi at 50mph!
new sending unit:
Cummins: $64. 00
Dodge: $199. 00
My local dealer says its covered under warranty... I have an appointment in the morning, and will let ya know.
Rob Hanson
1999 "Big Red", 3500 SLT QC 4X4 6 spd, 4. 10 LSD, Braided SS fuel lines, Mag-Hytec Rear Cover, Cummins E-Brake, Blue Box, DD3 Injectors, Banks High Ram and 14cm Wastegated Turbo, All-steel Cowl Induction Hood, Cummins RED Valve Cover, Rhino, Rosewood Kit, Scotty System, SportComp Gauges, TorkLift SuperHitch, Tekonsha Brake Controller, Rear Flood lights, Cobra CB, DeeZee Running Boards, BD 2WD Low kit, Air Lift bags, Hitco exhaust blanket, air horns and a Geno's "I tromped a Ford" decal. Member of BOMB! (WW NW Chapter)
MyPics.com (pics updated 01/20/01)
I'd rather be... .
Cummin than Strokin.
I had a 98 that had problems too. Oil press. gage went to 0 & then started working again. After I took it to them they replaced sending unit. It worked fine for several months. One morning going to work it did it again then started working again. Then about 25 miles down the road it did it again,this time ding dong sounded and fuel gage went empty. Then fuel gage started working again but still no oil pressure. So I figured it was acting up again. Several miles down the road lifters were getting noiser. Smoke was coming out. Checked oil was empty. Gasket on lifter cover blew out & dumped oil. So I guess my gage acted up & there really was a problem. They were going to put short block in it & use my head & turbo. I told owner what happened,that I did not want truck anymore so he made me a deal we both could live with & I have 2000 now. About 32000 now and no problems yet.
2000 Dodge 4x4 Quad Cab SWB 5-SP
Dealer says it's my sensor and put one on order under warranty. So, while in the shop
I rented another pickup as I have to have one for my job. Dealer pays for most of the rental of a 2000 4x4 350 Silverado Chevy. I wish my Dodge diesel was this quick! #ad
[Same thing happened to me the second day I had my truck. Called the dealer & they said a Cummins rep was in the area & wanted to see. Next morning, it was working fine & has never happened again. Cummins rep called me and I explained what happened, he said it has happened to many trucks between 300-500 miles on odometer. I guess mine just re-set itself, dunno.
2001 QC 4x4 DTH DEE, stock
