There is a quick test to be sure the VP-44 is bad. Involves removing the connector and grounding one wire and putting 12 volts on the other wire. I would do this before shelling out the big bucks for a new IP.
testing the VP44 - TDR Roundtable
Here is a snippit from that thread:
<table id="post661778" class="tborder" align="center" border="0" cellpadding="7" cellspacing="1" width="100%"><tbody><tr valign="top"><td class="alt2" style="border-right: 1px solid rgb(207, 207, 207);" width="160"><table border="0" cellpadding="0" cellspacing="0" width="100%"><tbody><tr><td align="left">
Agades<!-- google_ad_section_end --> <script type="text/javascript"> vbmenu_register("postmenu_661778", true); </script>
</td><td align="right" nowrap="nowrap">
</td></tr> </tbody></table> <table class="tborder" border="0" cellspacing="1" width="100%"><tbody> <tr> <td class="thead" colspan="2">
Offline </td> </tr> </tbody> <tbody id="collapseobj_postbit_legacy_userinfo10" style=""><tr><td class="alt2"> Join Date: Feb 2002
Old Reader's Rigs Gallery
</td></tr></tbody></table> </td> <td class="alt1" id="td_post_661778"> <!-- message --> <!-- google_ad_section_start --> <!-- google_ad_section_start -->OK
here we go guys
boy did I do a dummy
last night I used a test light as my hot wire
used the right pins and everything (#6 as neg and #7 as pos)
but
the test light will not transmit electricity and if it did it would blow the little fillament right out of the light
DUH!!!
this morning I got ahold of a cummins tester at my dealer (who didnt even know they had it till I explained it)
the pump worked fine so then I tried the shadetree method with just two wires (not a test light) and worked fine
the tach doesnt bounce around and idle is rock steady
hooked up the connector and Im back to normal again
(normal to my truck is a bouncing tach, crappy idle, and a stumble at 59 mph)
Im going to try a new APPS unless someone has any bright ideas
at least I should be able to rule out the pump now
Thank you very much for the help Rob
