24v w/ p-pump in a Solid Axle 1998 S10 ZR2
Hey I'm swapping a 24v w/ P pump (913) into my 1998 S10 ZR2 here in the next couple weeks. If anyone would like to help out, it's greatly appreciated.
First & foremost, I need some info on where to get a line flaring tool & nuts for the injectors. The guys from Scheids offered to help, which I may end up doing, but just wanted to give it a try.
A little background on the project.
I'm an offroader, and the S10 is the perfect wheelbase for me. First I decided to swap out the axles for something a little more stout. SO, I got a Kingpin D60 for the front, and a corp 14 bolt for the rear (stronger than a D70). I'm running dual transfer cases, both cast iron & gear driven. . Then I decided I would need a better powerplant than the 4. 3L V6.
SO. . I decided to go for the cummins. Always wanted one.
I stumbled upon a 2001 24v for cheap, and I decided to convert it to mechanical injection to avoid the hassles of the computer.
Now that you're up to speed. .
If ya wanna help me with the project, you are more than welcome. . I would like to be done by extravaganza, but definately by the four wheel jamboree.
Thanks,
Brayden
Thanks,
Brayden
