Ok. . Everybody who wants to know about an Allison have a seat
Here goes. .
All Allison's require a standalone computer. . Allison calls it a TCM, or transmission control module. It comes with all Allison transmissions. This computer does everything you need it to do. No need for a standalone computer, per say. . It already has one.
SO, all you have to do, if you were to stumble across one in a junkyard, is to just pull the transmission and the Allison TCM. On GM trucks they are located on the drivers side, on the fan shroud. It has a cast aluminum housing w/ an Allison logo on it, you can't miss it.
The only thing you need to do to retrofit an Allison to a mechanically injected diesel engine is to add a throttle position sensor to the pump. These can be ordered directly from Allison and hook up easily to a p-pump. Now that you have a TPS on the motor, you wire it into the Allison TCM and voila. That's all you need to do. The rest of the data that it needs is gathered from the various sensors on the transmission, i. e engine speed, turbine speed, and output speed.
Now you do have to have the correct calibration, but that can be had at any Allison Distributor.
I know which one, and i'm not telling
Curtis, when I get back from school, you're gonna have to come up and we'll slap a 2000 series in that motorhome of yours
