help! water leak from driver rear door
Leveling: Daystar vs. steel
Oil Temp Guage??
noticed a puddle of water yesterday under the drivers floor mat yesterday.
I figured it was from the rear brake light, so did some investigating and found it is definetly not from the brake light. i removed my rear seat, and pulled back the carpet from the driver side front and back so I could get a good look.
I placed a hose on top of the car and let it run down the drivers side of the car. After sitting inside for about 5 minutes water was flowing in from the back and flowing up front.
It seems to be getting by the inner door seal some how, but with the door shut, I cant see exactly where it is coming in. Any ideas?
I cleaned it up real good and replaced it and made sure it was fitting tight, and it is still leaking. I have the "newer" outer seal, and it is in good shape. The inner seal seems fine, so what gives? What should i do? should i fill the joint with weather strip adhesive and replace?
i can see exactly where it is getting by, but it is definetly the inner seal leaking.
I can take pictures an repost if my description is confusing.
thanks in advance for any help
Zander
Well I have tried a couple of things, and will report back later
I noticed my passenger rear door seemed tighter. if i push on it when closed it doesn't give much maybe a mm or two. If I push on the driver side it gives 3 or 4 mm. So I moved the latch in a little to make it fit tighter.
Also I removed the weather strip and applied adhesive where it seals against the opening.
hopefully this will help. I will let it dry overnight and test it again tomorrow before I put the carpet and seat back.
Boy i love taking a $40+k truck apart!
