After a two hour session at the car wash and @ $40 worth of quarters, I actually got most of the crud off my motor today. I'm preparing to do the KDP tab fix along with a new front seal. I also need to do a valve lash adjustment and replace the leaking valve cover gaskets. I decided to start there after fixing a small heater hose coolant leak that the washing also revealed.
I printed a copy of the valve adjustment instructions from Geno's garage and decided to try to find TDC with the timing pin. They hide that little guy real well! After more groping than I've done since I was a teenager, I finally felt something that just might be it...
I pushed; and it moved a little. I pulled; and nothing happened. Having read that it can stick, I pulled and wiggled it a little more. The whole thing popped out in my hand!
It appears to be intact. It has an o-ring in the middle and a small 1/8 to 3/16 inch long tip.
What is supposed to hold that little bugger in?
If I just shove it back in the hole, how do I know if it is in far enough but not so far that the tip gets sheared off?
I greatly appreciate any help.
Scott
Scott
