The bolt that attaches the passenger side engine mount insulator to the engine mount bracket fell out after the mounting bracket threads holding it in corroded completely.
I was looking through the Haynes manual and it says the proper procedure is to raise the front of the truck on jack stands, drain the oil, remove the oil filter, remove the engine cooling fan, and on my 4WD remove the front axle assembly for the passenger side mount. I also need to use an engine hoist to support the engine from the top.
Is there a simpler way to do this? I couldn't find anything in the TDR online issues regarding this replacement. Can I not simply take the load off the existing mounts by supporting the engine from underneath the oil pan? Do I need to drain the oil and remove the front axle assembly? Any suggestions would be greatly appreciated.
