This weekend we were pulling our camper up a grade and all of a sudden nothing. I pulled over and move the t-case lever around and at first it wouldn't go into neutral then it did and I got it into 2H. Pulled ahead about 50 ft. and that was it no more. Do you think it is transmission output shaft or t-case related? When I try to put it in gear and let the clutch out it sounds like a bucket of bolts rattling around. If it is the t-case what do you think could the chain break and cause this we weren't in 4 wheel drive. Maybe the t-case is stuck in neutral.
