Hey Talk is Cheap How mnay miles ya got?
Tire Runout
5-speed vs 6-speed clutch
I have a low 45,500 since 4/14/99 and no problems except 3 fuel sending units.
It will be in the classifieds when it has 455,000 on it #ad
99 2500 SLT QC, 2WD, 5 spd, 3. 54 LSD, Towing Pkg, Camper Pkg, Boards, Cab Lights, Fog Lights, Cobra CB, Not Bombed (YET)
My truck has 140,500 miles on it. It was worked hard for the first 135k. I retired it to a daily driver now. It also pulls very well in the stock truck classes at truck & tractor pulls. I love my truck and don't have any complaints. Nick
1995 Dodge Ram 2500, 4X4, White, Auto with Performance Torque Converter, lock up switch, 3. 54 gears, Psychotty air, Banks Power Pack, with Pyrometer and boost guages in pillar mount, HX40 turbo, 370hp injectors, Bullydog propane charged, No cat or muffler, 4" exhaust exits behind rear wheels thru 4" X 20" chrome tips, Go Rhino nerf bars, Wild Cat Flash Brush/Grill Guard with 2 150 watt 6" Eagle One lights tied into high beams, 5% tinted windows, Pioneer DEH 7200 CD player, 6 disc CD changer and 2 Memphis 3 way 6x9's and 1 Kove 12" with a Crossfire 404 amp, IDelta aluminum toolbox, Dodge bedliner, Heckethorn Nitro 9000 shocks and dual steering stabilizer, 16 X 8 Eagle Alloy 589 rims with 285/75/R16 Bridgestone Duelers M/T's, 16 X 8 Eagle Alloy 589 rims with 285/75R16 B F Goodrich A/T KO, New bed, front fenders and paint job due to some vandalism
My truck has 140,300 miles on it. I love it. It averages 16-18 mpg in the city and 22-24 mpg on the highway. It has been worked hard for the first 130,000 miles but I have retired it to my everyday driver now. I pull it in the stock truck class at truck and tractor pulls. It runs better now than when I first bought it. Nick
Back to the top... . 6600 miles and holding!! :)
01 3500 4X4 ETH/DEE, Loaded Except Leather and a Rear Slider. Spray in Liner, DeeZee Running boards, Yadda Yadda Yadda...
Hot Shot - "Although I may not have the highest mileage, 74,711 miles since March 1, 2001. "
How'd you manage that? I know our trucks are ahead of their time, but...
Y2K Red Stealth Sport 2500 4X4 QC SLT+, 5-spd, 3. 54 anti-spin, 265-75-16 LTX’s (There ain’t no such thing as options, cause ya gotta have it all, including: DC’s dead cow/vinyl interior and don’t stop anti-lock brakes. ) Stock, but not for long. Oops, too late. What silencer ring? (More fun than my 98 SST)
HotShot has me on the miles per year. However mine gets me to the job, as oposed to being my job
45,000 since May 10, 2000 about half the time pulling a large round baler at over 70 MPH
Y2K 2500, QC, 4X4, 3. 54LS, ST, 5 speed, SWB,Cummins E-brake,Westech Pyro and Boost Dual guage, 12 Disk JVC CD
[This message has been edited by Posm (edited 01-13-2001). ]
61,568 after 2 years and 2 weeks. No problemo man. #ad
John McEachern
Fort St John B. C. Canada
1998 12v, 4X4, QC, auto w/tc switch, air, tilt, cruise, 3. 55 gears, TST #6, Isspro boost/pyro/transmission gauges, BD VB&TC, CC industries headache rack and rails, JVC KD-SX949 Cd player, forest green, Brigestone Dueler M/T's 285/75/16, Eagle 16x8 rims, K&N airfilter.
Just sent in payment #1 9,700 miles in only 48 days.
2001 3500 4x4 H. O. 6 speed 4. 10, SLT, Cab and Chassis, 163" wheelbase western hauler stake bed 3" straight pipe, silencer ring AWOL, boost pyro gauge, K&N, Geno's one touch oil valve, Cobra 29,
ready to bomb
Big Red is ready to roll!
Wow is this post still alive ? COOL
If you want to hear some serious boasting the check out setdr.org discussion group. I would post it on the TDR but I am tired of typing
2001 ETH/DEE ST 4X4 SPACE SHUTTLE
YOu all have been in the rack to early/long-
96 (built may 96) picked up at dealer end june had 700k by jan 00 shifted in to nut'rl wating for someone to catch me. shy of 750k to date. oil usage same as when it broke in at 65k )one quart in 8k when it starts to move down i know it is around 8.
Items replaced on eng -fan support & oem belt(burnt off-support lock up). 580k-water pump 530- belt tension'er 545k, alt 400k,
rack adj(Valves) 115k-200k-320k check/no adj needed-400 adj- 522k not needed 609 adj'ed a couple, 700k ok-
Replaced radiator at 670k (should have at 600k) when started to have to keep close eye on temp.
lost 5 gear nut at 32k. reinstalled-came off again at 294k. inatalled new main shaft at this time and field tester split nut fix--
came lose 49k later-went back to my fix per discisson with a un named person,used there the 3rd fix nut (an not there tech)(there were close to my tech) and still in tac.
Oil -Century 15w50
Trans lube-castrol 75w90 syntec
Rear gear lube-Century 80w90 semi-syn
Replaced r. rear whl seal Warranty-TWO days latter (they screwed up -selling dealership)my self as i remember around 18k .
Brake job fronts replaced 580k-2/3rds used checked rears-Ok. replaced rears at 680k winter was close and didnt want to check again!
Tickets-----------ZIP.
Over weight... more times than i cared for.
Avg speed LOVE 2000 rpm/-
Gear used 99% of the time----------- 5th
shift point max rpm--2250. FORGOT----
Clutch OEM-- twisted the center out at 238. replaced-Replaced again 1500 latter(dip stick dealer tech did'nt do what he was told(install new transmission input shaft seal while it was transmission was out)back covered with transmission lube. Dealership (unnamed)in a un-named state with a vehicle mounted on top a pole!!!!!!!
96-3500 SLT EXT. CAB AM/FM/CD-RINO LINER. D-CELERATOR EXH. BRK-RED LINE VAC. OVER HYD BRK CONTROL- AIR BAGS W/HVY DUTY AIR COMP. PUTCO S/STEEL DEEPBOARDS FRONT TO REAR. REESE 20K 5TH WHEEL & GOOSE -REESE 20K HITCH BELOW W/17K RECEVER. CLEAR COATED & SOUND DEADINGING &UNDER COATED 5 SPD/W 4:10 MCHLN'S 235/16'S UNIDEN PC76/WEATHER-WILSON 1000 MAG MOUNT ANT. 4 WHL ANTI LOC BRK SYS.
You all have been in the rack to long!!!!!!!
(96-built in may) took delv. june 28 . 215 first year . 740k to date waiting for some one to catch up--700+ jan 00.
Originally posted by Huntmastr1:
Well the 98. 5 has 134,000. 30% pulling 10,000#'s the rest dailey driver in Houston.
The 01 has 11,700. purchased 1st week in July. #ad
Thought I would repost as this was brought to the top.
Now the 98. 5 Has 143,200 and the 01 Has 17,650.
106k miles, no oil added between changes 4-5k mi. just starting to get dirty.
"BOMB BUG" is getting worse here. #ad
97 3500 dually, ext. cab p/u,5sp,2wd,3:54,245/75R16,
straight pipe,105k mi. star wheel loose,plate slid forward, I like it
Ron
Holy Cow Evan... You must not ever shut it off!!!! I don't blame you! I'm still waiting for it to quit raining for a few days so I can take mine out of the garage... . Tuesday just might be the day! YEE HAA!
My 89 has 74k or 174k or 274k. My guess is 174k because theb upholstery is still in REALLY good shape, but I really don't know.
http://coffeewithJesus. homestead.com/web1.html 89 1-ton, Amsoil System 3000 5-30,K&N air filter, cleaned-up exhaust, Dynomax straight-thru, rebuilt pump, thermostatically controlled twin 14" Permacool electric fans, intercooler), modified 518 OD transmission, Gear vendors OD controler, R-134 refrigernt, louvered front fenders, 93 aftermarket smoothie grille, new Dupont Chromacolor black, black-and-red rubber rubstrip, black headlights, powdercoated bumpers; 78 35'Avion, 93 Lance 900 slide in with generator and power jacks. To see my truck, Click on: <A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1169022&a=10097213
Jesus" TARGET=_blank>http://albums.photopoint.com/j/AlbumIndex?u=1169022&a=10097213
Jesus</A> saves!
I've had mine for a year and a few weeks and currently have 31,500mi on it. Still averages out to 78 miles a day.
-Mike
'00 2500QC,4x4,LWB,Dark Garnet,6spd,3. 54lsd,SLT,DD stage II,Psychotty air,10-level PM3,Jacobs ebrake,Isspro pyro & boost gauges,2wd-low,Airoquip fuel lines,Smittybilt nerfs,BFG 285/75 AT's,Midland cb,Clarion 6-disc changer
