Sorry, you have that backwards intake charge is always heavier and denser than exhaust charge. If it wasn't the engine could not breathe correctly and would never run. The reason the exhaust valves are smaller is the same volume at lower density can flow thru a smaller area...
No need to apologise. You're confusing mass and density. Not the same thing.
Remove fuel from the equation. The mass of the air going into the engine is equal to the mass of the air going out of the engine. The number of molecules doesn't change (mass), just how tightly they're packed.
Now add fuel back into the equation. On the intake side you have air only. The exhaust side has that same mass of air plus the fuel that was added, therefore the exhaust has more mass.
stock turbo on a 2nd gen doesn't create enough drive pressure to overcome the boost charge. Even a stock 3rd gen with much higher DP doesn't do that.
An HX-35/12 runs over 40psi of drive pressure to get 30 psi of boost, and the engine runs fine at those numbers. Obviously there's more going on than pressure differentials.
The cam profile on a 24V has little to no overlap and that occurs at the end of the exhaust stroke when the bulk of the exhaust is gone. The overlap just promotes better scavening so the intake air forces more exhaust out. Exhaust gasses never back up into the intake on an design. Pull the cam specs and see where the overlap is in relationship to crank position and its apparent.
"Little" and "no" are not the same. The 24v engines do have some. And yes, it does occur at the end of the exhaust stroke because the inertia of the exhaust leaving the cylinder is what helps pull in the fresh air charge. It doesn't "promote" scavenging, the whole reason it exists is to
enable scavenging. You're thinking along the lines of a supercharged engine that is always running more psi in the intake than the exhaust. We're happy with 1:1 in our engines, but realistically we can get as high as 1. 5:1 (exhasut:intake) and still have a good running engine. The intake charge won't do much pushing by itself if the exhaust pressure is 50% higher.
Cam specs? Sure, I've looked at them when I was buying my cam. Notice that the higher-rpm cams for our engines have more overlap? Gotta keep the inertia of the gasses up for the high-rpm velocities.
AGas engines NEVER mix intake charge with exhaust charge. When that happens you get massive explosions in in the intake with things flying around. :-laf Only a hard parts failure will allow exhaust back into the intake on a turbo charge diesel.
Obviously a gas engine won't idle very well with 30psi of back pressure either. And diesels don't have fuel in their intake manifold. Let's keep this apples to apples.
Dirty sensors in the intake are almost always from using oiled filters and turbos leaking into the intake. An EB just makes it worse on a worn turbo by pushing pressure past the turbine and thru the bushings into the compressor. DP is high and there is no boost pressure to balance it. .
My intake boots are all nice and dry, as is my intake horn. My sensors will get soot covered. They were sooty after 20k miles with my exhaust brake on my new truck (not a worn turbo), and then stayed relatively clean for 80k miles with the exhaust brake off and my larger turbo on. The idea of getting dirty sensors from idling with an exhaust brake on is not new, or uncommon. Do a search.
If the IAT and MAP get fouled they don't read correctly and the engine over fuels. Simple as that. If your running an oiled filter get rid of it, otherwise your turbo is probably worn. Running 20-30 lbs on an HX35 is a good indication a boost leak is not at the root of the problem.
Not quite. A fouled MAP sensor typically sticks on the low side, preventing fueling since it "sees" low boost. A fouled IAT sensor will mess with the timing a little, since it is now insulated a bit with soot. Maybe you'll get a few degrees of egt swing, but nothing like the OP was experiencing. And our engines can run an HX35 to 40+ psi if the wastegate is tied down, so loosing 10-20 psi and still seeing 20-30 on the guage is very possible. 40-50psi of drive pressure and only 20-30psi getting to the engine? Yeah, that'll smoke and get a bit hot.
