Large compressor equal more air across the board and better air at lower boost. More air equals lower EGT's, simple formula.
The stock compressor is not up to the task of added fuel under heavier loads, better compressors with newer technolgy exist that are. Probably will have to swap the complete turbo out to get a chasis that will work correctly but its entirely doable with excellent results.
Once again, only part of the equation.
A turbocharger balances energy between the intake and the exhaust. It does not create energy.
To move more air on the compressor side, more energy is required from the exhaust side. Just sticking a bigger fan on one side doesn't create more energy. Like an airplane, just sticking a bigger prop on the front doesn't make it any faster (typically slower, in fact). Basic physics: you cannot do more work and
not require more energy.
A larger compressor wheel
can potentially move more air. But because of its increased diameter and bite, it requires more energy just to turn because of aerodynamic drag. So you'll end up throwing away some drive energy just to turn the bigger wheel and net less energy being passed into the intake. At big horsepower numbers with lots of fueling, this loss is minimalized because of the surplus energy available in the exhaust, and the benefits of the larger compressor are realized. But that's not the case here. Cruising along at 55 mph with the 5ver in tow using around 120hp on flat ground, there is no surplus, so you're netting less air into the engine due to the increased drag from the larger compressor wheel. Simple formula.
Larger diameter compressor = More aerodynamic drag
Same energy (exhaust) available - increased aerodynamic drag = less energy (air) available to the engine
Again, search around the boards. There are lots of folks that put bigger turbos on their trucks and wonder what happened to their towing performance, and now you're suggesting the exact thing to KBrennan. They believed, as I had at one point, and as you apparently do, that "large compressors equal more air across the board. " That statement is completely incorrect. I myself have wasted a bunch of money on turbos blindly following advice such as yours. Several turbo combinations later, I'm back to the stock HX35/12 and the truck hasn't pulled better, with cooler egts under most driving conditions.
This very thing has been covered over and over on here and other diesel truck boards. Do you want to go down this path again?
