Which will hurt engine life more, High EGTs(1400-1900) or High Boost
Pressure(60-80psi)? Since I've had the twins on EGTs have been way down. With the single I could hit about 1800 degrees and with the twins I can't get over 1400 degrees. My single was wastegated at 40psi and with the twins I can hit 80psi(that as high as the gauge goes). I only have ARP studs in the head and when I hit 70psi or above I can sometimes hear more of a rattle sound coming from the head. Is there anyway to tell if the head has been partially blown?
Brandon
Brandon
