I must be missing something. Am I the only one having problems with EGTs? Normal driving (empty) no issue, hard acceleration, it does not take long to hit 1500 degrees (pyro pre-turbo). I have no reason to believe the Pyro is bad.
Here is my set-up:
1. ’96, 2WD
2. 3. 54 (?) gears, w/aux US Gear Trans (as under drive)
3. Transmission – DTT (did it all)
4. TC - DTT 89 %
5. ISSPRO Pyro
6. BHAF
7. 3K GOV Kit
8. #10 Plate (adjusted all over the place, currently in stock position). Boost elbow (38-lbs).
9. 370 Marine Injectors
10. 3 ½ inch straight exhaust.
11. Timing – still stock, unless it slipped.
12. Valves – just adjusted them.
13. AFC – stock parts. Adjusted so many times I replaced the screws with Allen head. I think I am qualified to write a book on the AFC (minus the AFC Spring).
Numbers 7, 8 and 9 were from Piers, as he suggested.
Obviously, my next major mod is the turbo (or housing). However, when I read signatures, others have my mods without turbo mods, and I don’t hear about EGT issues.
With CAT and Muffler, ran 250 HP on Mustang dyno. Could not run full power because EGT’s were to high. I have installed straight pipe, and cannot see a major change although have not put it back on the dyno.
I am interested in thoughts and/or suggestions. If you have the same combination as I, let me know.
Wayne
P. S. Long post ok.
Here is my set-up:
1. ’96, 2WD
4. TC - DTT 89 %
5. ISSPRO Pyro
6. BHAF
7. 3K GOV Kit
Wayne
P. S. Long post ok.
