I appreciate the quick responses.
BHowayeck, were you running the Holly in line with the stock LP?
Steved/Rbattelle, if you run the Holly in conjunction with the stock LP, will fuel still get to the filter bowl should the stock LP fail? Thanks to all.
If you have the fuel-bowl-mounted lift pump, if it dies, the holley will NOT push fuel past the dead pump.
I'm not sure if the holley would be able to pull fuel past the intank pump...
However, if the holley blue dies, fuel can be passed through it without a problem... I have a holley blue knock-off on my aux tank, and I siphon through it the majority of the time.
steved
Thanks. Would you by chance know if the in-tank design pushes more fuel to the CP3 than the stock under-hood mounted LP I'm currently running? I ask because I haven't read anything on here about this and do not have much faith in what the dealer is telling me.
I just installed a Glacier Diesel Walbro pump. Great kit, everything you need to install. Mine replaced the fuel filter mounted LP. It is mounted on the inside of the frame rail just in front of the fuel tank. I'm getting 20 psi at idle and cruising through the stock filter, drops to 17psi at WOT.
John, just curious, did you order from Glacier? They're asking $419 for the standard kit. thanks
