Just replaced my stock baby H1C with a modified unit - direct bolt in but 16cm turbo and 58 wheel - man what a difference
No more discernable spool up lag, 22# boost where I was only getting 12 before, EGTs down about 200 degrees, etc.
So what's next? I've looked at a lot of threads about pump tweaks and I'm really confused
The sticky on performance says:
OK, so what are these modest adjustments - looking for some more HP but don't want to hurt mileage or EGT too bad.
Also - pump timing is stock and I know that to increase it you have to turn the head of the pump up - do you just loosen the bolts and move it or do you have to do the TDC thing?
TIA
Modest adjustments of the injection pump. These are generally the "free" power enhancements that are fairly easy to make. They should be done in a methodical manner to assure the desired results. Generally they can all be done by the owner with a few simple hand tools and a small amount of time.
TIA
