You won't regret the 2 Honda EU2000's. I have 50 amp service to my trailer so I use a 50 to 30 amp 'dogbone' and then a 30 to 20 amp adapter. When the two are in parallel it will run my 15,000 btu main AC and I even turned on the 13,500 AC for a short time and it seemed to do alright. Using the AC plug limits you to 20 amps, and I popped the breaker with the AC and the microwave. To get around this you could wire up, or buy, a rig to use the power from the parallel plugs.
I have one of those 50 amp cheater boxes that I was going to try on the generators but haven't, so I don't know if that will work. Theoreticly, I should be able to pull 20 amps from each generator to each side of the 50 amp circuit. Max amperage for the two is only 36.
Reasons I bought the Honda's:
1. They are quiet.
2. They are light weight.
3. They are compact, making them easy to handle, store, etc.
4. I have two generators so I have options given an emergency.
5. They are QUIET... ...
