20mph roll, level 5/5, Boost pegs 40psi and the tires break loose!
And I can see why you guys say the 6 speed isn't going to be all that effective once you get to the low 13's. . 2nd and 3rd go to fast to be effective. . Well, if I didn't have bald tires then 3rd wouldn't be so bad.
I can FOR SURE see the requirement for a clutch and drive trian and tires (slicks? 4x4?) that can handle a 3rd gear hole shot inorder to get any descent drag times with the 6 speed.
Slippage till about 1800 - 2000rpm and then let go, and crack 4th gear and hang on, hope to heck you don't hit revese as you slip 5th,
Also, what is the peek PSI for an efficient HX35 stock turbo? What would be the next step or two up from this. ultimate goal is to put tis truck just a bit faster then the SRT-10 and be done with things. I have a Z06 or an BMW M3 to own some day ya know.
