Hot restarts
Amsoil incompetence
H.P. drops down in O.D.?
Got about 18,000 miles on my truck, but noticed
this habit of it since I've had it: After running
on the freeway for say a few hours, then stop at a
roadside quickmart, stop the engine, pop inside
for less than 5 minutes, crank the truck and it
doesn't fire right up.
Usually takes at least two extended cranks (~2
secs each). The truck usually fires up instantly
every morning, almost like just a couple of turns
on the motor at most.
When I stop off for an extended stop, like to eat
lunch or something, it seems to fire back up OK.
I also usually don't kill the motor when I refuel,
partly to avoid dealing with the restart hesitation.
Doesn't sound like a serious thing, an annoyance
at best that can be worked around, just wondering
if there is something to this or should I let the
motor idle longer before I shut it down? I know
my Case tractor says to idle it before shutdown to
cool the turbo, but I sometimes forget, shut it
down, hop out to clean the plow, get back in and
it cranks right back OK.
2001 QC 4x4 SLT Laramie, Cummins 24V, Auto, Stock.
I believe there is a TSB for this. A buddy had the same problem with his truck and they reflashed the ECM and all was well with the world. Check dave fritz's web site, he has all the TSB's listed for our trucks. There is a link to in in the links section.
Good luck.
Uh-Oh. If it's what I think it is, you're about to have a nightmare. This just happened to the machine that I operate at work. In the morning, it would start instantly. At lunch, I had to crank it for 30-45 seconds. Then it got to where I had to use ether to start it as it progressivly got worse. Turns out, the injection pump got weak, then finally self destructed.
GET DC TO CHECK YOUR INJECTION PUMP IMEDIATELY!!!!
I went and found the TSB that exists for hard start when engine is hot...
Hard Start when Hot
This may help, but the injection pump is another source of concern, I would get it checked out soon.
PROBLEM SOLVED:
Thanks to all that replied, got the dealer
to reflash ECM with update and alls well!
This truck and this site are awesome!
Have to admit, I was a Ford diehard, but have a fleet of Cummins on the farm: 2 B5. 9s, a 505 and a
N14, so that and the response like I got from TDR was a decision to buy the Cummins Dodge, and so far it was worth it!
This was the first dealer service since I drove it off the lot, other than something that was there to start with...
First day, alternator went out, now ECM upgrade, not bad in my opinion, keep truckin, Cummins Dodge!
Thanks to all,
JD
