Competition How come 5th is so hard to get into on NV5600
Competition Modified diesel class
Competition 215 vs 175
When i'm at the drags its so freaking hard to shift into 5th gear. Once im launched my foot doen't come off the gas pedel until i have to gingerly shift it into 5th. In doing so I have a slower et and loose a lot of my boost. Does anybody else have this problem , or a solution.
I'll give this a bump to the top for you...
I've got a similar problem on mine. If you go to grab 5th quickly when you've got your foot in it, it doesn't want to go in right away. If you push it, you get a little grind. Pausing before going in clears it up, but that does hurt the ETs. Mine just started doing this not long ago. I think I've got some hydraulic problems in the clutch, so a new master/slave is going in. I'll see if that helps straighten it out.
Hey Dan,
Well, mine isn't necessarily hard going into 5th, but more than once while drag racing my truck down there, I have missed 5th and ground reverse for a second :mad:
