Details here: TDR Privileges
It usually ain't that easy. If you have access to a smoke wrench, you could heat it up and then twist it off. If you don't you'll need a cutting wheel or sawzall to cut it off.
If you have the factory muffler still on the truck, you'll have to cut it off. I used a sawzall. Worked just fine. Just remember to leave enough pipe to install the replacement to.
Some places might refuse to do the job because the Geno's pipe is a muffler elimination kit & they'll say that is illegal. Try the small, local guys in your area.
