Sure, again; I had a well documented (on this forum) problem of low power that turned out to be dealer sabotage. But in the process, I had the injector pump rebuilt, new lift pump, fuel filter, checked and rechecked the TST cam and it's position in the AFC housing, adjusted the govenor to hit right on the nose of the cam plate, verified my AFC diaphram was good, unhooked the vacuum line to the waste gate for more turbo boost. The starting issue is only that I now have to step on the accelerator pedal when I start the truck, as opposed to never having to do that before the injector pump rebuild. Pre rebuild... . starts by just hitting the key, post rebuild, cranks for 3-5 seconds without giving some pedal. I've had air in the fuel line before so I am familiar with those symptoms, this isn't anything like that.
