Papa Delta said:Mine isn't! I have an 04. 5 with blah blah blah (check sig) and running down the Expressway at 65 I'm in the 500 degree range. I never see exactly 200 even from a cold start. I always wait until I get to less than 300 deg before turning my engine off. Is your probe pre turbo?
rbattelle said:Although what B. G. mentions would seem logical, I've noticed that ambient temperature has at best a tenuous relationship to cooldown time.
In any case, I can't say I've ever managed to stop my truck with the post-turbo EGT above 300. Just the act of slowing down and coming to a stop is enough to get the EGT down below 300 post turbo. Usually I'm at 200 by the time I complete a stop, so I just wait several seconds and then shut down. My point is, unless your pulling off the highway from 80 mph in a panic stop, you can be sure your EGT is below the 300-degree safe temperature.
Heck, cruising down the highway at 65 mph on level ground my EGT is rock-solid at 300.
-Ryan[/QUOTEr]
Just how far "post" is your probe? Must be in the tail pipe extension. You might need to check the accuracy of your EGT gage setup? bg
B. G. Smith said:Just how far "post" is your probe? Must be in the tail pipe extension. You might need to check the accuracy of your EGT gage setup? bg
rbattelle said:It's in the elbow, about 2. 5 inches downstream of the turbine. Penetrates beyond the internal radius of the pipe. I believe it reads accurately in that location.
On Edit: highest temps I've ever seen were around 800 give or take 50. I have a gauge that's color coded and calibrated for post-turbo installation. Everything's green up to 900 degrees. Link.
-Ryan
Kennywould said:Ryan
Quick question since pre and post install is always an issue in the forums, if there is about 300 deg difference between the two, I usually shut down at 250 - 300 at pre turbo would it not be much less at post turbo? I'm not jerking you, just asking because that +/- 300 always bothered me!
PKnoerzer said:I have the same set up as Lightman, and see the same temperatures. Cooling it down to 300 degrees pre-turbo is adequate isn't it? I normally shut down after the needle drops under the 300 mark.
rbattelle said:What does all this mean? It means if you're sitting there idling and your pre-turbo gauge indicates 300 degrees, your post-turbo temperature is most likely 250 or less. Give it a few seconds (maybe 10?) to be sure the turbo case temperature has dropped, and shut 'er down.
rbattelle said:What I'm about to say is my educated opinion... take it or leave it. -Ryan![]()
CJEliassen said:The turbine might be glowing red yet your EGT's are 200. So, in order words, you can not use an EGT probe to determine when your turbine is cool.
