I know one thing for sure, there is a lot of intelligent people here with varied opinions and knowledge. I for one have driven and operated all types of equipment with turbo diesel engines without pyro gauges and common sense is to idle down to cool down, whether its for seconds or minutes, it depends on how hard its been run. If you pull 10,000 up the road for a while you wouldn't shut it down in 15 seconds, same goes for running an empty truck, you don't need to idle it for 10 minutes. Same if your pullin with a 48re, you have to idle it in neutral for some time if you been pullin heavy, regardless of what the pyro says, you know that the oil has to pump thru the cooler to cool that transmission. You can't rely on one gauge to make your decision to shut down! Your brain is the most important gauge, it and common sense should keep you out of trouble, IMHO
