WStoops said:My pre-turbo temps run 500 to 600 at 65 mph. Hard pull up a steep hill, unloaded will get to 1500 if I don't let up on it. It idles around 300 degrees.
DPKetchum said:If it was brought up by a NEWBIE it was like don't even bother with installing one then.
DPKetchum said:You may like it but its not good info your reading from it.
rbattelle said:Hey Kennywould - I'm a Steelers fan too, doesn't that mean all my opinions are automatically correct?![]()
-Ryan
DPKetchum said:You may like it but its not good info your reading from it. Having to read it and it says 800 degress but let me think. Is that really 1200 degrees cyl. temp or 1300 or humm. By the time that you get that sorta its toast. Its a easy install I'm sure post turbo. Fact is thats not were its suppose to go to be any real benifit.
rbattelle said:I respectfully disagree because this assumes no heat transfer between the turbine and the exhaust stream. Given the very low specific heat of air I expect the exhaust gas temperature to approximate the turbine temperature within just a few degrees.
CJEliassen said:EGT's do not give you any indication of the temperature of the metal.
rbattelle said:I very respectfully disagree.
On edit: I'm surprised you don't watch the EGT gauge before shutting down your helicopter. Is it because the engine manufacturer dictates a minimum idle time? Of course you want to idle for a bit even after the EGTs reach a safe level on a turbine engine so that the case, and rotor temperatures can settle down and (perhaps most importantly) to account for the possibilities of hot zones outside the "view" of the thermocouples. With my truck, even when the EGT gauge indicates a temperature well below 300 I idle it for 10-20 seconds just to be sure the bearing compartment for the turbo (through which no gas passes) has time to cool a bit to prevent coking.
If the EGT gives no indication of the metal temperature, then why would anyone want to look at any EGT gauge at all? You're implying the EGT could be 1100 and the metal could be 300, if there really is no connection between EGTs and metal temperature. And if there is no connection as you imply, where does the metal heat come from? Radiation alone?
On further edit: you must idle your turbine engine because you need to be sure the bearing temperatures fall below the coking temperature of the oil. There is no convenient way to measure bearing temperature using a thermocouple in the exhaust stream. I expect the turbine blades, and vanes to be right about the same temperature as the EGT gauge indicates.
-Ryan
CJEliassen said:I have ran turbo charged engines with EGT's at 1700F and the turbo is glowing red. When the power is reduced, it can take 30 seconds or even a minute for the turbo to stop glowing.
opjohnny said:Going to have to find a SAE paper on this.
rbattelle said:And what was the EGT when the turbine was red hot? I'd bet you all the cash in my wallet it was above the luminosity temperature of the materials in the turbo.
Countdown timers are certainly useful - especially for those without an EGT gauge. It's a way of automatically idling for the suggested times in the owners manual.
I think the big thing is the bearing compartments, which don't get any air flow through them. Certainly these cannot be conveniently measured by EGT thermocouples and so even if the EGT is low it's good to let things idle for a bit to be sure the bearings are cooled below 300 degrees (approximate coking temperature for the oil).
You seem to suggest that the difference in specific heat of air and steel is of no bearing on the problem. You also imply that there is no heat transfer between the metal and the gas (as you admit to implying). If there is no heat transfer, then where is the heat from the turbo dissipating? For that matter, how does a heating coil work? By your logic, if I blow air across a resistance heater that's been heated to 1000 degrees the air that passes across it will simply remain at ambient. Get my drift? You seem to be ignoring heat transfer here, but I'm not that brilliant so maybe there's a part of the problem I'm not quite seeing.
This is an interesting discussion... I'm not trying to argue with you per se, I'm just curious why your view of things is so greatly different from mine.
-Ryan
