How many Miles on your dodge 24V?
How many Miles on your 24 valve?
  • 0-10000
    Votes: 123 4.6%
  • 10000-25000
    Votes: 208 7.8%
  • 25000-50000
    Votes: 330 12.4%
  • 50000-75000
    Votes: 365 13.8%
  • 75000-100000
    Votes: 382 14.4%
  • 100000-125000
    Votes: 341 12.9%
  • 125000-150000
    Votes: 271 10.2%
  • 150000-200000
    Votes: 329 12.4%
  • 200000-250000
    Votes: 161 6.1%
  • above 250000
    Votes: 142 5.4%
  • Total voters
    2,652
4th gen wheels on a 2nd gen ram
A new approach to the well known front end problem
Yes Bob Cochran the dealer replaced my pump under warranty after I paid my deductable. I noted that one my drive into town that my fuel pressure gauge dropped to 0 PSI at 1/2 trottle for a about 1/2 mintute and then for next serveral miles (about 9 miles) the guage was very erratic reading between 2 PSI to 8 PSI. So when I got to the dealer I told them to look and my lift pump and after they check it they replaced it with no questions asked. I like my dealer.
1999 4x4 5 spd, 30,600 Miles
1 Rt Front Axle seal
1 A/C Evaporator
1 Set front Disc Pads
1 Emergency Brake Cable Attachement
1 Transfer Case Shifting Problem
38,000miles in 13 months and still running strong. one lift pump, and a 7mm socket (inside the NV4500) took out the transmission and clutch at 12,000mi.
1998. 5, Build date of 01/28/98 Has 86,000 Miles on it.
Have replaced the Follow due to Failure.
1. Lift pump at 50k.
2. Fan Clutch at 75k. running hot, not working
3. Thermostat at 75k. running hot not opening all the way.
4. Rear transmission seal to Transfer case at 75k.
5. Brake pads,shoes and rotors at 50k (warped and worn out).
Not Bad, Concidering I hammer the Poor White Ogre quite often.
Doug.
8 months,,,,, 30,000 miles,,,,,, four TC's and 3 transmission's :D
Now all is well with transmission, thank you DD and DTT :D
1998. 5 has 58,000 miles. I had the following failures:
1. Replace overflow valve fuel return line due to a crack at a bend
at 40,000 miles.
2. All freeze plugs in the head replaced at 51,000 miles.
3. Re-flash of the transmission due to slipping in overdrive at
53,000 miles.
No other problems at this time.
Overall opinion at about 49K:
Still very happy with the green monster
Starts great in the very cold weather
Major issues:
Axle seals front and back
(maybe due to 90% dirt roads)
Fuel level sender unreliable
(never top off tank, never have problem)
Self induced clutch issues... . :D
Lift pump on last legs
(discovered during today's filter change saga)
Trailer hitch recall
Too expensive to have two of them
99MY, 18. 5K miles 90% towing . No engine defects. Never been back to dealer.
99 QC 3. 5 AT. Pyro-boost -fuel press. & transmission temp. Mag hy-tec
diff. & transmission covers. Delo 15-40. Cummins filters.
4th owner at 85k miles. Noted when purchased:
Seal leak on transfer case.
Intercooler hose keeps blowing off (fixed now)
transmission 1-2-1-2 stutter (okay now)
Must have had 3 tire changes, got 3 different brands on it. none of them the Michelins the paperwork said it came with.
Has gooseneck hitch below bed and 10k receiver hitch. someone pulled somethin' fer shore.
93,200 miles today, no trouble since purchase 12/2003.
98000+MILES
98. 5, 3500, 4x4, auto, stock, pull's 40FT. RV.
15mpg empty, 10mpg pulling
no major problem yet
lift pump@87000 and three thermostat's
it's been a good truck
32K miles. No failures except for a preemptive lift pump change (11psi idle, 8 @65, 5 @ WOT).
