how much are you supposed to open up the restriction in the return...
Throwout bearing problem?
what does it take to make a 4x2 5speed a 4x4
all of that fuel is going to the vane pump or do you have fuel going in the return side too?
Single feed, stock inlet. This winter I might figure out what check valve KTA is running and dual feed into the return like him since I'm using the same dual feed regulator as him.
plz keep us posted on your results
is this your daily driver???
thanks, don
Mine? no, I can't get more than 1000 miles without some sort of driveline failure. It's a toy I'm trying to make power with and when I'm done messin with the VE I have a 16:1 p-pumped motor with enterprise cam in it that will get put in the 90 to make a puller out of. I drive a 96 4x4 daily with automatic,cruise, air and a sweet ride. Hope to have the 90 up and going next week, I have to get a couple driveshafts made up and the fuel cell ready.
if you aint worried about it poppin the seal out then throw some pressure at it as is. (but be sure to keep us posted... :eek:)
if you dont mind the work pull your pump and throw 3 or 4 screws at it
you know what i mean? some small button head allens with part of the head holding the seal in. or if you really want to mickey it just peen it with a center punch?
i have a pump here but there is no seal in it and no gear on it so i dont know how much room you will have back there. again, please let us know what you do and what happens
thanks
don
