pwerwagn
One of our cummins (2002 3500 4x4 auto) seems to have a boost problem. We recently finally installed the guages (boost, pyro, fuel press, trans temp) and the truck only makes 14psi! Is this normal, as I am led to believe this truck has one of the 9cm housings? I thought it should still make 18psi or so. The truck is completley stock and has EGT problems on long, steep hills pulling about 10,000lbs in colo. BTW, we are always above about 5,000' altitude if that has anything to do with it.
