Engine/Transmission (1998.5 - 2002) how much can i add to my injection pump
Engine/Transmission (1998.5 - 2002) Occasional Erratic Idle
Engine/Transmission (1994 - 1998) No Throttle Response..........
I have a 2001 Dodge 3/4 ton 4x4 ext cab. piped chipped and cold air intake. the chip i put in it is from van aaken. the reason i bought this one is it said that it would stay within the limits of the injection pump. the chip was only rated for 60 hp and 140 torque. can i go with a bigger chip, or bigger injectors. the cold air is afe. the exhaust is 4" straight through.
The easiest next step would definately be injectors. Be careful with the next step, your transmission (auto - or clutch) will not appreciate the extra power. Fill out your sig and we could help you even more with your setup.
How much HP are you wanting? Do you tow, if so how much? What are your goals for the truck? By knowing this good guidance can be given. I agree with John that probably injectors would be your next step, gong with a "bigger chip" will tax the pump more.
If I can answer any questions please feel free to email or phone.
Doug Smith
717-557-7060
