Froadin said:Does anyone know how much restriction the new filters have? The 2nd gen is about 5 psi of restriction for just the filter. Figured the new one would be similiar, but not sure.
Btw, doesn't the FASS create too much pressure then? If the injection pump only wants 10 psi and 45 gph, the FASS is way over doing it. Which would be creating too much extra fuel pressure / heat. Just thinking out loud, and still trying to figure out the 'perfect' transfer system.
Thanks for the help, it is really helping me narrow down my choices.
Froadin said:Steved, thanks, I wasn't sure about that.
But if I ran a 12 psi spring, and I turn my box up to 5, I stand a high chance of dragging it too low on pressure/fuel?
Besides, it seems like they are getting a lot closer on the VP44 for determining that the extra heat of the fuel drastically shortens the life of the IP. I can't see how the CP3 would be any different in this case as it still uses the fuel for cooling, and the more you recirculate the fuel, the more heat you are putting into it.
How does the RASP compare on this point? I know it flows more with RPM, but it also seems like it is overkill in a bad way.
BTW, just so you know, I am working on a design to fix these transfer pump issues for the 2nd gen. It is a different approach then anything I have seen, and I believe it would work perfectly for the CP3 as well. But I have to know the perfect ideals for stock and modified.
But if just getting a FASS is more cost effective, I might not bother with the 3rd gen setups. Seeing as I have both, I do have an interest in taking care of both systems.
Thanks again.
Ed
And in the real world, how do you avoid this
MFalkinham said:His point was that the pump he uses is liquid cooled, which he feels is desirable.
rbattelle said:I thought the point was to keep the fuel cool? If you're using the fuel to cool your pump, then you're heating up the fuel! I suppose a fuel cooler could be plumbed easily.
I would prefer to run an inline style pump for reliability's sake (no need for a seal between the drive motor and the pump body), but no one makes one in a range of flow rates and pressure that I'm willing to try.
-Ryan
99Supercab said:The Walbro will operate comfortably at 60-80 PSI, how much more flow do you want, lol. Also, the Walbro is an inline pump. Here`s a link that has a flow chart for the Walbro pump
