JStieger said:The only thing that still confuses me is that if the pump is rated to 60 psi, when will it actually output this pressure and blow fuel everywhere???
Kry226 said:Superduty's experience (before the CP3 bypass) was that the stock filter canister lid blew at +60 psi. A few suggestions to monitor pressure is to put a FP gauge PRE-FILTER. If pressure drops, that indicates FP problem. If pressure goes up, that indicates filter blockage.
rbattelle said:You got me backwards. I meant inline pumps flow WAY TOO MUCH! My engine is stock, it sure as heck doesn't need 60 psi or 200 GPH!
I'm happy with 11-12 psi and <100 GPH.
-Ryan
99Supercab said:Gotcha now. If you`re all stock, you have no need to upgrade, right ?
rbattelle said:"Need" is pretty subjective.
-Ryan
99Supercab said:Well, your kinda right. What we`re seeing on my dad`s 02 is that the pressure is also going up becuase of the return line restriction. So pressure going up is not only indicitive of filter blockage, but return line restriction too.
using a pump that is only capable of putting out 30 psi puts you back to "being near the limit of the pump".
cerberusiam said:Thats the point of running a pump that is sized to your application or "limit". Flowing only enough fuel for injection needs plus enough for cooling is what engineering is about.
In this case bigger is not better, more is not better. If 30 psi is enough to provide adequate flow for the needs then 100 psi 3x overkill and all the fuel is going back to the tank with all the problems associated with that.
The pump will not be running at 100 psi, probably closer to 20 psi with regulator and appropriate bypass. The point is to bypass near the IP, letting the IP take only the fuel it needs, while the rest is sent back to the tank.
if "just adequate" was the desire, then why is the FASS so popular
cerberusiam said:HTML:using a pump that is only capable of putting out 30 psi puts you back to "being near the limit of the pump".
The agruement about inducing more air bubbles into the system makes no sense to me. You can`t tell me that between the cavitating of the fuel in the fuel tank, and the operation of the VP itself doesn`t induce air bubbles into the system anyway. I may be wrong on that point, but my reasoning makes sense to me on this one
3. Heat. This one is interesting to me. I do understand everyones arguement on this point, but I think ppl are missing something here. In our particular install, we are not using the stock lift pump at all. We are using the Walbro pump only. Since the Walbro is only running at roughly 25-30% of its capacity, I don`t really see how it is adding that much more heat into the system than was already there.
cerberusiam said:HTML:The agruement about inducing more air bubbles into the system makes no sense to me. You can`t tell me that between the cavitating of the fuel in the fuel tank, and the operation of the VP itself doesn`t induce air bubbles into the system anyway. I may be wrong on that point, but my reasoning makes sense to me on this one
One of the main features of the FASS/AirDog is removing the entrained air from the fuel before sending it to the IP. Why wouldn't it make a diference if more air is introduced constantly pumping more fuel back to the tank? Read some of the posts about the FASS and the effect. Smoother idling, smoother running, quiter operation, better power, and in some cases better mpg. These things have been around for years in the OTR trucks and seem to make a difference. As far as introducing air in the VP, that is supposed to a closed system and if you are getting air in the high pressue side of the IP there are other problems. The extra filtering and fuel delivery are really bonuses in addition to what the FASS addresses.
HTML:3. Heat. This one is interesting to me. I do understand everyones arguement on this point, but I think ppl are missing something here. In our particular install, we are not using the stock lift pump at all. We are using the Walbro pump only. Since the Walbro is only running at roughly 25-30% of its capacity, I don`t really see how it is adding that much more heat into the system than was already there.
Where are you putting the bypass? At the IP? or ??? Where are you mounting the pump? I was stated previously the place for the bypass was at the IP, and superdutie's setup does the same. Where do the return lines run? Right alond side the engine soaking up heat as the fuel flows back to the tank. Now lets bypass twice the needed fuel, soak up heat as it returns, and dump it in addition to what the IP is already returning back into the tank. Do you begin to see the issue here.
Like I said before I am not knocking the design, just questioning the wisdom of solving one problem and introducing a couple more.
I think that this is merely a justifcation on your part as to why you spent 800. 00 on a 120. 00 fix.
cerberusiam said:One of the main features of the FASS/AirDog is removing the entrained air from the fuel before sending it to the IP. Why wouldn't it make a diference if more air is introduced constantly pumping more fuel back to the tank? Read some of the posts about the FASS and the effect. Smoother idling, smoother running, quiter operation, better power, and in some cases better mpg. These things have been around for years in the OTR trucks and seem to make a difference.
cerberusiam said:As far as introducing air in the VP, that is supposed to a closed system and if you are getting air in the high pressue side of the IP there are other problems. The extra filtering and fuel delivery are really bonuses in addition to what the FASS addresses.
cerberusiam said:Where are you putting the bypass? At the IP? or ??? Where are you mounting the pump? I was stated previously the place for the bypass was at the IP, and superdutie's setup does the same. Where do the return lines run? Right alond side the engine soaking up heat as the fuel flows back to the tank. Now lets bypass twice the needed fuel, soak up heat as it returns, and dump it in addition to what the IP is already returning back into the tank. Do you begin to see the issue here.
