Engine/Transmission (1998.5 - 2002) How much HP can a HO pump support
Engine/Transmission (1998.5 - 2002) Trans cooler lines leaking
Engine/Transmission (1994 - 1998) HX35W Turbo help needed
No personal experience just going off what I read on hear awhile back. You can run 200 HP injectors but the hp will taper off on the top end when the pump can't provide enough fuel. The consensus seemed to be around 150 HP injectors were about max with a HO pump. Again I can't prove this, just what I was told.
