How to add class to an ST
under hood lights
Need a good exhaust brake switch
It's been a little slow around here, so let's see what I can get get started... . #ad
I think if you check junkyards, it should be easy to find some wrecked SLT trucks. With a screwdriver and some patience, the "SLT" badge should pry off of a wrecked 1500,2500, or 3500, giving you an excellent add on for an "ST" badged truck! #ad
2001 SLT dominantly valved ETH quadcab 4x4 dually
icq61308432
Yes, dmurdock is correct: it IS easy to find a wrecked SLT at the junkyard. Evidently, independent studies have discovered increased atrophy in the arms and hands of SLT owners due to lack of effort involved with rolling windows and unlocking doors. It seems that when faced with an emergency situation, SLT owners have less strength to execute a recovery move and therefore are more likely to "barrel" into the obstacle ahead of them. There is help though: carrying around lots of hand putty(and using it) exercises the hands. For the arms, installing a device similar the one Sylvester Stallone used in the award-winning movie, "Over the Top" is recommended, on both sides for automatic transmission owners...
jacko
'01 2500 QC ST 4WD SWB, Patriot Blue/Agate.
DEE/ETH, Trailer-Camper-Plow, 3. 54 LSD, rear-slider, cab-lights, 265's.
Personally, I have found that if one practices rolling the windows up and down without power, this does an excellent job of maintaining adequate muscle mass in both the hands and arms for proper navigation of an over-assisted SLT. #ad
<font color=#990000>~<font color=#990000> '99 2500 SLT <font color=#990000> ~ QC ~ 4X4 ~ LB ~ Auto ~ 4:10 LSD ~
<font color=#000000>*<font color=#990000> BD E-brake<font color=#000000> *<font color=#990000> BD Autolock<font color=#00000> *<font color=#990000> Gear Vendor OD<font color=#000000> *<font color=#990000> Jordan Research T-brake <font color=#000000> *<font color=#990000> Bullhide spray-in Liner<font color=#000000> *
<font size=-2>... Lookin' for the 'RE' to go next to my 'TIRED' so's I got more time to Play!... <font size=-1>
[This message has been edited by Rattlin (edited 06-24-2000). ]
dmurdock... ... . you started it! #ad
I think you ST guys need to exersize those arms and hands for personal gratifacation purposes #ad
Ha hA ,
Ron
I still have the SLT badges I removed from my former 99 Ram if anyone wants them.
My 96 was an ST... I got tired of dragging out the brick to use as my cruise control.
-Mike
I think there would be alot of slt's in the junk yards because
1. the driver would be constantly looking at the thermometer to see if it was suuny or snowing out.
2. the driver was looking at the compass to see if they were on the right side of the road, going east as they wathed the sun set.
3. pulling jammed CD out of the player while attempting top speed.
Why go to a junk yard to get a slt badge, when Dodge should proudly put a ST badge on our trucks. Are we considered second class because slt owners interiors look like they should be drinking cup of hot tea from silver cups instead of coffee from plastic cups.
Missouri Mule 96 White 4X4 ST club cab,(grey int. ),5 spd, 3. 54 reg dif, 8 ft bed, 1 ft high cheater boards, front and side of bed,Pofile V bug shield,
99 Freight liner FL60 blue Cummins 24v 215 hp, 520 torgue,6 spd 3. 59 no spin rear, 16 ft dry box (white) 19. 5 low profile tires,Weight 11,000, gvw 23000, 11 to 12 mpg
Bill Thomas (Wild Bill)
Hey now that is something I would like to have; Cruise Control; how about like a tractor or airplane. A constant throttle device like a pull cable that will hold throtle in the same place instead of sissified constant velocity like on the SLT that waste gas by engine braking going down hills and giving gas going up. You could call it tractor mode; it would smoke a reg crusie in gas milage also. Simple just like ST. UNITE ST BROTHERS
Mad-Scientist
2001 ETH/DEE ST 4X4 SPACE SHUTTLE
I think you guys are exaggerating the level of convenience in an SLT. I mean, have you felt the detents in-between each speed of the fan's blower motor? What about switching from off to ac to heater, man! And don't even get me started on those power windows!... have you ever pushed one of those buttons? I'm already developing callouses from having to hold the button down the WHOLE time it takes for the passenger window to lower.
ps. . Don't worry about my callouses guys... my manicurist is simply a "magician"... you can't even tell where I broke a nail trying to open that barbaric gas cap
I think ALL the badges look cheap and trashy!
Including the Ram 2500 on the door! They will all be pried off soon and replaced with chrome or stainless PW emblems or some form of Cummins badge!
What the heck does SLT mean anyway? Not to be confused with ferds XLT, right?
GENE
1997 BOMBed 4x4
NRA Member
GLTDR Member
LIC-ROC Member
