How to I test Alternator output to my batteries
AlphaREX NOVA headlights
A/C line blockage
JField
My 2007 Ram 3500 Laramie 5.9 doesn’t appear to be charging the batteries. The guage used to charge around 14 volts but doesn’t appear to be charging now.
How can I measure the level of charge coming from the Alternator to the batteries using a multimeter.
Thanks for any help.
Measure voltage without the truck running and then again with the truck running. I'd check them with it running after a short drive to make sure the grid heater is off and the alternator has had a chance to kick in.
Just simply put meter on the terminals, if charging, voltage will be above 13.0 volts. Resting battery voltage is 12.5 - 12.8 volts on average. Set multi meter to DC volts when testing.
The factory gauge is a lie-o-meter, it shows what ever the ECM wants to show you.
Take a multimeter to confirm. Also measure the battery's independent resting voltage.
If that all is good you can use an amp-clamp to measure current with the engine running.
