How to remove pinstriping
draining automatic trans
Durapuke a non-issue
Anyone have an idea as to how to easily remove the pinstriping that came on my Dodge? Solution, ?
1999 ISB 5spd 4x5 LB QC, original PMax, 275 Hp injectors.
If they are a stick on decal heat them up and peel them off. If you have help peel the decal while someone else uses the heat gun.
This message is in the wrong forum it will probably be moved.
Jim
Patriot blue Y2k 5sp Stealth 2500 (markings removed)QC,SLT+,leather, camper,TT,lsd,3. 54,4x4,hd xfer case,Geno's dual gauge,DD IIM's and boost module,K&N stock filter, Tekonsha Sentinal,Reese 12 hole wd hitch, ARE lid & bedrug liner, Sony 10 disk cd changer.
[This message has been edited by jims (edited 08-11-2000). ]
3M makes a wheel to fit in a high-speed drill that removes striping and decals without damaging the paint underneath. Try a parts house that caters to body shops.
Bill Lins Wharton, TX 98 2500 QC SLT,12 (the CORRECT # of)valves,NV4500,3. 54 LSD,Manik grille guard,Psychotty Air,Amsoil everywhere, Reading aluminum utility body and bumper,Optima yellow tops- silencer ring, cat,& muffler all stolen.
I used a spray on pinstripe and decal remover from NAPA on my old Toyota,it worked excellent. Sometimes it will be a different color shade under the pinstripeing due to sun fade on the surrounding paint,give it a little time in the sun and it will fade evenly.
[This message has been edited by illflem (edited 08-11-2000). ]
Unless the removal method involves extreme highspeed and the heat generated therefrom #ad
I guess this will go into "Non Engine/Drivetrain".
