Early 04 Cummins with 80k miles. Flabed with hydraulic hay baler installed. In a previous life, this truck was used to haul hay bales. That is all I know.
Truck was eating midshaft bearings so I installed 1pc driveshaft just last night. Man what a difference. Smoother shifting (NV5600) and almost makes it feel like better throttle response.
I SHOULD HAVE tested with a gopro camera previously, but didn't. Another guy asked me if I ever figured out the root cause of carrier bearing wear (the rubber mounts always would tear after only 3 weeks of normal driving)
This all got me thinking. IF I do have axle wrap which was eating these carrier bearings, am I now more at risk of hurting transfer case (N271d) with a 1pc driveshaft installed?
I will post a pic later, but I'm not sure if the truck is completely stock back at the leaf springs/axle, or if these short pieces of leaf spring material (stacked to make a block between axle and leaf springs) are added blocks or if they are oem. Truck does t sit high and doesnt appear to be lifted.
Anyhow, how can I test for excessive leaf spring wear, or if there is excessive axle hop/wrap/etc? Can measurements just be taken (loaded or unloaded?) Or can I put a gopro camera under truck and just drive it through the gear shifts to see what is happening?
Do my (probably) worn out shocks come into play at all here? How about the motor mounts? Truck only has 85k miles but I've read that IF it lived a hard life previously, (hauling heavy wet hay bales on bumpy terrain) things like leaf springs and motor mounts can wear out much faster.
How should I approach this and do some testing on my leaf springs, motor mounts, etc?
Should I add torsion/traction bars perhaps?
Thanks for any advice here. I would really appreciate it.
