took the HX40 off this morning (1/2 hr) and the shaft isn't broken but the bushings or bearings are worn/toast as I can move the cold side impellers up/down and side to side and they make contact with the housing thus prohibiting any movement at all--scored the the housing a little and wore down the impellers on the cold side a little---getting ready to send it back to Majestic shortly
Talked to Sportbike and he's gotten Holset & Majestic together so hopefully something will happen--I don't think Holset will do anything since Majestic worked on it, but he felt that Majestic should and would--we will see what they say after they get it and tear into it--I ain't holding my breath, but hopefully they've decided to stand behind their warranty and Briar Hopper & I will get something out of it---
Briar Hopper is right that this isn't Sportbike's fault-he just recommended Majestic, but Majestic has started to do something different to the turbos by putting bullets on both sides and I don't think they did that before--Marco does your turbo have any bullets??? This could be the cause or Holset's HX40w quality has taken a turn for the worse--Majestic said they don't clip these things either, so it will be interesting to see what they determine the cause of these things failing and what they intend to do about it.
I'd be a little leary about putting on a Majestic tweaked HX40, if it has the bullets, until this can be figured out---chris
