"The use of H2O2 as a propellant takes advantage of the decomposition of 70-98+% concentration hydrogen peroxide into steam and oxygen. The propellant is pumped into a reaction chamber where usually a metal (esp. silver or platinum) catalyst triggers decomposition, and the oxygen/steam that is produced is hot enough (>600 °C) either to be used directly or to combust a fuel. As a monopropellant (not mixed with fuel), it produces a maximum specific impulse (Isp) of 161 s (1. 6 kN·s/kg), which makes it a low-performance monopropellant. The famous Bell Rocket Belt used hydrogen peroxide monopropellant. When decomposed to burn a fuel as an oxidizer, specific impulses as high as 350 s (3. 5 kN·s/kg) can be achieved, depending on the fuel. Peroxide was used very successfully as an oxidizer for the low-cost British launchers, Black Knight and Black Arrow.
Compared to hydrazine, peroxide is less toxic, but it is also much less powerful. Peroxide gives a slightly lower Isp than liquid oxygen, but is dense, storable, noncryogenic and can be more easily used to drive gas turbines to give high pressures. It also can be used for regenerative cooling of rocket engines. " From en. wikipedia.org
Any one thought of using it ?
