Just wanted to post for those that haven't done this or that wondered if they could do it themselves. I have a motive brake bleeder - www.motiveproducts.com and used the universal adapter which works easily/perfectly. I bought the adapter because I had originally purchased the european brake bleeder kit - which threads right on the reservoir cap of my mercedes. In any case, the universal adapter fits our trucks (and any other round capped reservoir I could imagine).
Using the motive couldn't be easier. You attach the bleeder's adapter to the fluid reservoir and pump it up to 15psi (the motive has a little pressure gauge). Then you simply go down to the bleeder valves on the brakes and attach the length of clear hose that comes with the kit, and loosen the bleeder valves. Basically then you just have to let the thing drain until you no longer see the old fluid coming out of the tube, only new/clean fluid. Repeat at the other three wheels and you're done. Pretty easy and definitely only requires one person, no brake pumping, nothing tricky.
I used Valvoline Synpower synthetic dot 3/4 brake fluid - which was the best they had at Advance auto parts. It had the highest wet boiling point of 330F, so that's what I went for.
