I installed my DD2's today.
What is the Registered Weight of your Ram?
Lockup Shudder?
Need I say more? O. K. I will.
The difference between stock with no 'EZ' and DD2's with the 'EZ' is a full -7 seconds 0-60!
Y2K Black 3500 ISB 4x4, 4:10 LSD,Auto,QC,SLT Laramie,"EZ",DTT VB,DD2's,LB, Polished Stull Billet Grill & Fog inserts, Chrome Smitty-Built Step Rails, Mopar Chrome-Tipped Mud Flaps, A-Pillar mounted West-Tach Turbo/Pyro/Trans Temp gauges,Rancho 9000's set at '1',Diamond Plated Tool Box, OEM U. R. Bedliner + other stuff.
Fact:The First Fords' had 'DODGE' Engines! The new PSD's need them!
Welcome to the world of DD2's... I have a set installed also and wouldn't trade them for the world. These things are awesome to say the least.
Kev
The only thing I'm dissappointed with is that I still cannot burn my tires! But I guess that's a good thing because all this power propells my truck instantly foward, and with my new DTT VB, I waste no power #ad
RobbyRam,
What were the reasons you chose the DDII's over DDI's or 275's?? The reason I ask is because I'm in the market for one of these three types of injectors. Any problems at start up, or with smoke with the DDII's?
00' White 3500 SLT QC 4x4,Leather, 4sp. auto, 3. 55ax, Banks Powerpack, Putco's Master Boss Boards,RS9000 Shocks/RS5000 Stabilizer,Bully Air Horn
I'm also interested in the DD2's. What's the cost and how much smoke?
99,A/T,BD exhaust brake,Torque/autolok,BD plug&power,DD 4"exhaust,275's,14cm turbo,TST PM-3-adjustable,Dunrite converter and VB,Mag hytec transmission and axle covers,upgraded fuel lines and some other stuff. Pulls pretty fair. 29 foot Cedar creek 5er! Gross 20,K.
RobbyRam, & K Arts What are your EGT's running with the DD 2's and EZ. Im running DD 1's with out a problem and would like to up grade to the DD 2's, or maybe DD 3's if I can get away with it pulling 12,000 # of Trailer, Horses And Mules to Colorado and Montana to hunt Deer and Elk.
1999 Quad Cab 4X4 1 Ton Cummins, Auto 3. 55 LSD K&N D&D#1'S stright piped w/ resonator. Smittybilt Outland Grill Guard,Nerf Bars & Rhino Liner W/ Reese 5VR & G/N hitch.
... i installed my DD3's today ... hehehe ... on the down side , PE on , my lack of fuel pressure has reared its ugly head #ad
. . funny thing now is my fuel pressure gauge drops as fast as my speedo goes up #ad
[This message has been edited by Mopar-muscle (edited 03-25-2001). ]
biggrizz
i have not pulled a real trailer yet but my egt's will not exceed 1300 until triple digits. i was on edges mustang dyno and simulated a 20k gcvw and made some runs up some different grades. this would equate to about a 12k trailer. i wasn't driving but told him to maintain 75mph in 6th gear. i was watching egt's. we started at no load and slowing started up the grades. we stoped at 6%. and my egt's were under 1200 so we kept going we had to stop at 10% becuase my egt's hit 1400. but we were in a closed room with a little tiny fan blowing air into the front of my truck. i'm sure with my setup i can pull 13k the speed limit up a 8% grade and pobably more without egt poblems.
jim
2001 eth, ez box, dd2's
My Ram Pics
CMiller,
I probably should have gone with DD3's as per the recomendations of both HVAC and JDonnely. Ie: with all the work installing any injectors, I guess I should have gone with the DD3's! However, the DD2's deliver as promised: at least 60-70 HP, and a whole lot of torque to the rear wheels. And, since I've already paid for another Dynojet run, I'll post the numbers without and with my 'EZ' this coming week.
robby , don't sweat " ALL THE WORK " , today was the 4th time my valvecover has been off for an injector swap , and it won't be the last #ad
, i wish i could put it all on with velcro #ad
[This message has been edited by Mopar-muscle (edited 03-26-2001). ]
Getting ready to put the EZ and DD2's to a real test. Planning a trip from Phoenix to Moab, UT the 7th of April. In tow, 9000 gooseneck flatbed with 2 rock buggies.
The DD2's and EZ driving in and around Phoenix and the grades north out of Phoenix with this weight hasn't been a problem.
Let the RPM's drop below 1700 though, and the EGT's will climb fast.
I will go from 1000 to 7000 and settle back down to 5500 Ft. with several steep grades in between. One climb in Mexican Hat, UT is 10%.
Fred Swanson
Co-Owner
Canyon State Components, LLC
www.canyonstatecomponents.com
'00 QC,SB,4x4,Auto,3. 54 w/LSD,Trailer Package, Tow Package, DTT's VB & TC
