petersonj
hat the batteries need to recharge for a bit after being depleted.
The only way to really know is for @GAmes to duplicate the symptoms by leaving his grid heater switch on with the engine idling until the "GEN" light comes on. Turn of the grid heater switch and leave the engine running. Using a good voltmeter (not the one he used to previously to check his batteries) and check voltage at the batteries for a few minutes. If the voltage stabilizes well below 13 volts, then the alternator is not charging. If voltage continues to slowly rise above 13 volts, then the alternator is charging. That should offer a solution to this debate.
@GAmes , it sounds like your grid heater switch is a maintained switch. Why not use a momentary switch? Mine has been wired with a momentary switch since the truck was new. Can't accidentally be left on.
If it is decided to do the test, my bet is the alternator will be still charging. But who knows - I think I was wrong about something once before.
- John
